Since a month I'm usimng Xperia Pro (build: 4.0.2.A.0.62).
Until last week the GPS get on when I used apps like 'Maps' or 'Runkeeper'. When I start those apps now, those apps said that ther is no current location availible. Indeed, before I notice the GPS icon in the top of the screen, now I don't.
When I go to the general settings and to 'Location en security', and re-activate 'GPS-satellites' then the icon appear in the top of the screen again.
Just for a short moment and then it's gone!
What can I do to solve this?
Thanks.
Begin by trying to repairing the phone software via PC Companion.
http://www.sonymobile.com/gb/tools/pc-companion/
Let me know if the problem remains.
Thx Johan,
After re-instal the software and re-installed the apps every thing seems to be working properly.
Hopefully it will more then 1 month.
