I was updating to ICS using PCC when my computer crashed.
Now when i try to turn on the phone first Sony logo appears and then something like warning sign and little phone below .
I tried searching forum for the solution but as far nothing helped.
________________________________________________________________
Backup everything as it will erase all data on phone (sms, contacts,apps)
Update/Repair your phone via PCC or SUS
PCC (PC COMPANION) – Repair your software with this .First do the setup without connecting your mobile to pc.(only connect when you are asked to).
Do it as follow >> PCC > SUPPORT ZONE> SOFTWARE UPDATE> REPAIR SOFTWARE (written with blue)
PC Companion http://www.sonymobile.com/global-en/tools/pc-companion/
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
or
