The galary is missing in my xperia S after the ICS update.My SI number is 1257-3318.Also i am not able to see the galary shortcut on the home screen.Moderators please help me resolving this issue.Can i reinstall the ics again.Also the camera button is not working when the screen is locked.PLEASE HELP.
Make sure you haven't disabled it
Go to settings > apps > all > scroll all the way down and you will see the list of disabled apps, check if album is there, tap on it and enable it
Since your camera button isn't working as well
You must reinstall ICS on your phone
________________________________________________________________
Backup everything as it will erase all data on phone (sms, contacts,apps)
Repair your phone via PCC
PCC (PC COMPANION) β Repair your software with this .First do the setup without connecting your mobile to pc.(only connect when you are asked to).
Do it as follow >> PCC > SUPPORT ZONE> SOFTWARE UPDATE> REPAIR SOFTWARE (written with blue)
PC Companion http://www.sonymobile.com/global-en/tools/pc-companion/
the Gallery app it's called Album
open the camera -> menu > quick launch
Hey what ever you call it but the album is not showing ....pls help
tried rebooting?
ya i rebooted still the same issue ..please help me feeling helpless MODERATOR's Please help......
settings > apps > all > photo > clear cache or force stop it then reboot it
Nice π Now it works π
NaznaΔite sviΔanje na Facebooku
