Hey Guyz,
I had a problem where I couldn't make calls properly due to an OS curruption.. So, I did a repair on my once again updating the ICS.. After that I felt like the phone is little slow whenever I go into an app and returns home..
So, I thought of completely formatting the SD card & also updating the OS to ICS by a repair.. can I anyone tell me how to do that or any other proceadures??
You can format you SD card in the following menu.
Menu > Settings > Storage > Erase SD card.
You can run the repair feature via PC Companion.
Support Zone > Software update > Repair
(Do this while phone is not connected)
