hello i have changed my password yesterday its been working perfect until now i try to enter the password and it says not correct so i was wondering if there is a way around this and its a password thats letterd not pin or pattern
so is they a way round this?
you have 2 options
1) keep trying
or
2) repair your phone with SUS or PCC
doing so will delete everything on your phone except pictures, music and videos
hi thanks for the fast reply and what is SUS & PCC
because im not fust about deleting it all just wanna get back on my phone asap
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
those are the only 2 options, either you keep trying to remember or you will have to lose everything
ok thanks ill try them now ill reply if they do not work or if a problem
sus will work, if your phone is requesting a PUK password then that's up to your carrier/network to provide you with.
hello again but this doesnt seem to be working on my linux laptop...
you need a PC
If you forget the phone security password then try default code like 0000 or 1234 to reset it .If it doesn't reset your mobile then visit Unlocking4free.com here they provide master reset code for some Nokia DCT phone and Alcatel old mobile models at free of cost using this code you can reset your mobile and again set a new password
