How to create a Folder in home screen? I did't find this option in ICS.. Can anyone pls help on this..
Thanks.
There is no option anywhere to create a folder.You need to drag one icon onto another icon to create a folder
Please Mark
Got it..
Thank you meamit & Jatin
How can i deactivate the vibrate while typing?i already unchecked the 'Vibrate on touch' option, but still i'm getting vibrate only when i'm typing some thing. Please advise
Where did you uncheck vibrate on touch?You are supposed to do it
Settings>Language and Input>Settings(Xperia Keyboard)>Sound and Viberate
This works in ICS
Are you in ICS or GB??
Please Mark
Using ICS only..Its Done now..
Thank you jatin.
Anytime.
If you are rooted then please visit
http://talk.sonymobile.com/thread/56641?tstart=0
http://talk.sonymobile.com/thread/56642?tstart=0
If you want to root:
http://forum.xda-developers.com/showthread.php?t=1886460
Please Mark
