Hi all,
I accidentally removed the FM-radio app from my Xperia SP...I thought I was turning it off :-S. Can anyone tell me where to find this app and how to reinstall it?
Thanks in advance,
Niels
EDIT: found it allready...how to delete this message...
How did you removed the app?
if you disabled the app then
settings > apps > all > scroll to the bottom > FM radio > enable
