finally..after waiting for months and just about to sell my xperia neo, finally ICS for my neo though the si no still not in the list..still fiddling around as i just updated my xperia 10 minutes ago..i'm quite happy with the performance for now..but i have a few questions..
1. the update received today comes with build number 4.1.B.0.587..is this the latest on that everyone is talking about?
2.whats the difference between xperia gallery and normal gallery?
3.how to switch to front camera..no shortcut on camera apps as in GB.
4.how do i get rid unnecessary apps that comes pre-installed?do i need to root my phone?if yes, how to?
thanks in advance !
hi adrian91
1. yes,it's the latest ICS build for neo.
2. Xperia gallery is the default gallery avaliable in GB version and normal gallery is the updated andriod gallery in ICS.
3. You can switch to front camera by tapping the scene mode shorcut inside camera app which is exactly on the left corner of your phone when camera capturing screen is active.
4. You can disable unneccesary apps by following
Settings
Thanks
hi adrian91
Settings
Thanks
thank you so much..as for the front camera..when i tap on scene mode, i cant seem to find any to switch to front camera..and i just wanna try the face unlock but it display face unlock couldn't start..does this means my front camera is broken?
There is no need of activating front camera for using face unlock. When you go to Settings
but when i tap on face unlock it display face unlock could't start..it doesn't seem to be a big of a deal actually..just trying out new features..but thanks for the help though..:smileyhappy:
i have everything except for front camera..:smileycry:
Much better now, BUT AGAIN BATTERY DRAIN!!!!!!!!! What the ?!!??
