HI GUYS TODAY I BOUGHT THIS XPERIA U PHONE>>>FAST CAPTURE IS NOT WORKING....PLEASE HELP ME TO GET OUT OF THIS PROBLEM
press and hold the camera button for 2 seconds > make sure you press it all the way
unrelated topic, if you have some time please check this thread
also check this
open the camera app > menu > quick launch > launch and capture or launch only must be selected
If he has ICS installed, he can also use the slide-button from the lockscreen.
I prefer the mute slide-button though, from GB.
