I m a Sony xperia Sp user since 1 nov 2013 and from 4 nov. I m facing the prob of touch I update the latest software from service center still the problem not resolve then I replace it by new handset. The new handset also have the same problem touch not reponse while charging I use the original charger and still facing the same problem........WHAT SHOULD I DO CAN ANYBODY HELP ME TO FIND SOLUTION
Thanks for help me I m very very thankful to u
as per the condition whatever will happen I will tell u........ And again thanks.......
i have problem relating pinch zooming its frustratiing
But the costumer care told me that there is no refund policy.......
Yep,that option is no longer available because the device had been changed multiple times with a newer device(even though it posses the same issue).
I had to agree with the replacing method.The only way with minimul risk.But how about wait for 4.3 update first and then only change it...Maybe it will be solved???Who knows...
