I m a Sony xperia Sp user since 1 nov 2013 and from 4 nov. I m facing the prob of touch I update the latest software from service center still the problem not resolve then I replace it by new handset. The new handset also have the same problem touch not reponse while charging I use the original charger and still facing the same problem........WHAT SHOULD I DO CAN ANYBODY HELP ME TO FIND SOLUTION
Your are not the only one that face this issue.This more to software related issue.A software glitch.
Look at this:
http://talk.sonymobile.com/t5/Xperia-SP/Xperia-SP-usb-charging-and-touch-problem/td-p/342802
Look at this:
ya I know i m not only one who facing this type of issue but how to re solve it........Pleas help.........
Thanks for your concern...
OK I will wait till dec. Can u please tell me the market report of zr. I think to replace it with zr. Should i?
Well, I'm not the only one with the problem of the screen. The touch response of the screen is slow, and at the top where the notifications does not work on the touch screen, hopefully solved soon!
Is someone is here whose SP is perfectly running..........................and the touch is properly working
I bought a xperia SP on November 6 November and this problem with the touch screen is slow to respond to touch, and there areas of the screen that does not respond, and cuanesta horizontal position the patalla not respond very well, I hope solution .
