Hi.. I have a problem also about facebook inside xperia.. I cant activate it. Even though I turned on the sync. After I checkd the box to enable it, and agree to the terms, it just go back from unchecked box. What should I do to activate my facebook inside xperia?? Help!!
my facebook is working but,, my "Facebook inside Xperia" is not working.... help..
First check that if this happens independent of Internet connection. Try both mobile networks and Wi-Fi. You can also check if you have any proxy settings in your APN settings that might be causing this.
If not you can try reinstalling the phone software to make sure it's just not a software glitch.
Thank you for your reply..
i dont have a Micro Sim yet,, is that affect the "Facebook inside Xperia?"
. and is there any more solution rather than reinstalling the software? because i did that already and nothing changed...
Which Mobile You use....?
i have same problem in my Xperia Z when i start uploading pic from "Xperia for Facebook" it is always finished upload but i cant see that pic on my facebook account.
this problem occuer after when i update my Kernel Version.
It may not show up on your timeline, however have you checked yor albums on your Facebook page?
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
@Sam wrote:It may not show up on your timeline, however have you checked yor albums on your Facebook page?
