Hi guys, I have installed Emma, but am having a huge difficulty with the registration. Now get this straight, it's not that I'm too unintelligible to move the .ini file to the installation folder, no. It's that even AFTER I have moved the .ini file to the correct folder, it STILL tells me all this registration crap. I am having difficulty on this matter and getting tired of this constant login page.
This is the list of folders and files at the installation folder:
Bundles
Configuration
jre
licenses
log
plugins
settings
setup
temp
updates
****customization.ini****
Emma home page
Emma
Emma.lock (???)
uninst
customization.ini's contents are:
developerworld/enable = true
What am I doing wrong???? I am not admin on this account but I am using the password to open the application... Please help!
Hi - this is a consumer (as opposed to developer) support forum. Practically no-one here will have a clue what Emma is. You'd be much better off posting on forum.xda-developers.com or stacktrace.
*sigh*
Ah, well... I'll wait a little longer...
I know what Emma is and have used it and have it installed
So to go through things
You have installed it and then copied and pasted the Customization.ini file to the installation folder
If asked did you overwrite and that should be it - On start up of the program after doing all that it should work without asking for registration
So I've just uninstalled mine and redownloaded and installed
Without doing anything with the customization file I have the below on Emma startup as I assume you have
http://imageshack.com/a/img829/7732/chgu.jpg
Then in the Emma folder via Program files I have the below files
http://imageshack.com/a/img191/2525/f0q5.jpg
After copying the customization file it starts with out issue
http://imageshack.com/a/img62/4079/6zg1.jpg
However more files have been added to the Emma folder - An extra four
http://imageshack.com/a/img22/1856/llv2.jpg
As much as I am grateful for your efforts and answer, I can assure you that the customization.ini is in the correct installation folder and that it is still not working. I will try on an administrator account and see.
how can i unlock xperia lt18i. i try flashing the phone with emma tool but is showing me this,
Unlock what? From network, Bootloader or somerthing else?
Emma will only work with unlocked bootloaders - For anything else use Pc Companion for updates
