whenever i post anything from mobile. on facebook i see that only "sent via mobile" . i want to see tht "sent via sony erricson xperia mini pro" .
how to do tht ?
ok so i checked it
if you update your status from timescape it shows via sony ericsson xpria
i dont think we can do that
wait for other users to reply..
shaddy it is possible with HTC,samsung then y not wit SE . so sad to know this
well some of the post are made as " sony ericsson" or xperia arc , i saw one...but still for normal things it shows only mobile
you have to post through that horrible app/widget Timescape for it to show Xperia
i dont want to use it
rohan you can try..
whats so horrible in it shaady & uliwooly ? let me also know it .
it takes time to connect to facebook and update evrything..even the slightest thing , timescape updates it..and you will see only timescape....
i think..
when you long press any app icon , the share option pops up , and if yu drag towards it and share "it says via sony ericsson..
i think so..try it...
but yes you can only share applications etc which you can drag...
