Dear,
Is it possible to get a notification instantly when someone messages you on the chat function? I have only been able to get one after 30 minutes (closest option)
Thank you in advance,
Willem
Hi, I doubt it is possible .... Facebook app setting for refresh interval is 30 minutes (minimum).
Alright, thank you.
Weird that a 'chat' function can't be instantly recieved, but mail can.
Also another thing, with timescape the messages that are incoming are labeled 'one hour ago' when it's actually just a few minutes ago. So I think the timer is off one hour, can I fix this? It's also like this with mail I think
Are you using Facebook Messenger app?
what about installing facebook messenger ? https://play.google.com/store/apps/details?id=com.facebook.orca&feature=search_result
I am using the facebook app that was on the phone when I bought it
Thank you all.
Does anyone know why all the messages that I recieve with like facebook and e-mail display a wrong time? They are recieved like a few minutes ago but it says 'recieved one hour ago'
Could it be phone date & time settings?
It's automatic, seems nabeelraza has the same problem too..
SMS messages do give the correct time, just email, facebook,.. displays one hour earlier while it's not
