I have sent my work rota by email to my Xperia S in Microsoft Excel format. When I open it on the device more than half the cells have no data. Anyone have a solution or explanation for this?
try this app and see if it works
https://play.google.com/store/apps/details?id=com.dataviz.docstogo&feature=search_result
mark helpful and correct answers..
Works perfectly, thanks Slimshaddy.
you'r welcome..
