if you are using the Gmail app press MENU -> Go to labels -> draft
on the Email app -> MENU -> folders -> draft
Thanks uliwooly-wooly.
That's great - saved me from going mad! The answer's always simple but it's knowing where to go which is the trick.
Hi again - do you know of a way, when using email, to only have the latest emails download instead of having all of them download each time? i.e. I don't want to keep 1,000s of emails in my phone, I just want to mange recent ones.
Anytime, make sure you backup everything just in case something goes wrong and you need to repair your phone or do a factory reset
Backup & Restore app
Use this links to download the apk
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkhttp://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
neither the Gmail nor the Email app allow you to do so, but as I recalled, this apps will only the last 4 days of emails and the Email app the last 20 emails
Great - this could be exactly what I'm after. Which app is it?
try Maildroid or K9
open your Gmail -> press MENU -> MORE -> Settings -> tap on your gmail account -> Sync inboxes and labels -> inbox
