I think i did a big mistake...after updating to ICS and after a few days i realised tthis Operating sistem is "heavy" - battery drains faster, eats more ram, moves slowly...and so on.And i decided to go stock firmware. And...after a few sites readed how to flash your phone i downloaded to my pc Flashtool and after that i think i installed a ST18 firmware on my xperia active. I did a big mistake...now my phone doesn`t start and flashes black screen.
Neither sony pc companion or SUs doesn`t help now because my phone doesn`t start when i connect to usb and is not regognized....by the pc.
After that i downloaded the good soft and now the program flashtool can not install the good firmware...what should i do ? Please.
X_activo is right...someway
What happened to me is called brick
6. Turning the "brick" into a smartphone
If you had unlocked bootloader and did OTA(Over the Air) update, then you probably ended up with a dead phone, aka brick. Don't worry, it is not completely bricked, still can be saved!
I reflashed first with "Xperia_2011_FreeXperia_ALL.ftf file" and after that i installed "ST17i-Active_4.1.B.0.431-1254-6360_SONY.ftf" - 372,922 KB and i think this is a good soft instead the ICS that i haved in the past - more 3G signal...and runs more faster.
Thank you guys that u have the pacient to reply to this post.
connect it to the wall charger take the battery out put it back on and let it charge don't try to turn it on
When i connected the wall charger and pulled out battery and back on, the phone has tried to start and "died". The red led is showing ( i think he is charging ). and nothing more. What i should do next. ?
do as uliwooly says, just let it charge for a while, a red led means battery is low/or empty..
I know the minis are simillar but, it it possible to install wrong fw? does'nt pcc or sus detect this?
Ok...i`ll wait untill the led is green and then i can try to start the phone ??
did you tried to repair it w/ SUS?
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
I tried both the problem is that when i connect my phone with usb the pc doesn`t recognizes the phone ( card)
I dunno what to do...
try to reflash it... http://forum.xda-developers.com/showthread.php?t=1444841 follow the steps and it will work... goodluck!
