if they will install a front facing camera in ARC .....then it will be my next phone.............sony go for it because i m a great fan of xperia family....
you should check the Neo, it has a frontfacing camera
or wait for PRO.. if Im not mistaken, it has front camera..
I haven't seen Arc, but I anticipate to buy PRO.. if you would compare, there are more features in PRO than Arc..
the neo has a front facing camera too, so I'm debating between arc or neo if I buy a SE phone
I havent been able to find an app that will allow to use the rear camera for videocalls, do you know of any apps? besides fring
