Hey guys . I updated my SP yesterday with android 4.3! Undoubtedly , It works really fine in most of the categories like Power management , Performance and ... . I myself has sent a post about a solution of top part of screen problem . But again I'm facing with the problem and it can not be solved anyway . What I'm really shocked about is that the top part of screen doesn't work even with this version! It really depressed me :smileysick:, so I want to find out the solution to solve this annoying mistake ! I hope it is not hardware problem which can not be solved easily .
Do you still have the same problem as me ?:smileyconfused:
I updated to 4.3 and the problem is still there, sadly.
The 4.3 update doesn't resolve the top part of screen issue. Unfortunately.
YEs , U are right . Although the GHost Touch is solved ,but top part of screen does not work yet!
Sadly, the 4.3 update does not fix the top-of-the-screen problem. I've had the screen problem since the end of December-early January.. I really hope there is a fix for all of us that are suffering with this problem because I got this phone for Christmas as I thought it was a really good phone but sadly, with this, Sony has made me feel let down.
i dont experience any screen problem but the advice i can give is to back up data , factory reset and repair via sony update service
These fruitless actions do nothing! I have been doing these for a long time ...
sony is releasing update for 4.3 ,hope that will solve ur issue
I hope so!
