Hey guys.. the screen of my xperia acro S is damaged.. if i change to new one.. will the mobile be still waterproof.?
thanks
As soon as you break the seal unless you have the tools to run a pressure test then I would not risk testing the phone to see if it is waterproof - I would accept the screen is fixed and handle with care around water
If you take it to a Sony repair center it should
Agree that only Sony Centre can replace the screen due to water resistance. However, call and check first as owners of XZ were told that cost could be very high.
ok... repairing at sony cost too much ..around $135 anD it will take time...
on ebay the digitiser+LCD cost $50
So i better repair my mobile myself..and am just concern about the waterproof..
