Phones with unlocked bootloader can't update kernel / rom using the OTA options so why is it that update center still bother to check? Why doesn't update center check the bootloader status before it even bother to check for updates?
That said is it possible to disable it?
I'm not sure why it's configured in that way but I agree that it makes no sense for the UC application to check for updates when running with unlocked boot loader. I will pass it on.
