If i update a firmware n my xperia device via pc cpmapnion or via update service,and if i flash the same firmware through flashtool to my xperia device,does it makes any difference at all.
i am having some problrms with my xperia sola ,i have tried to repair it via pc companion and upadte service but it was of no use,could flashing my phone with flashtool help me??
i have contacted to the sevice centre ,the service personnel said to me thet he will flash it with flashtool and problems will be gone but he is on leve till 4 jan.
so plz tell me thet if there is any difference in flashing with flashtool and running update sevice.
contact Sony, using flashtool COULD void your warranty
http://www.sonymobile.com/global-en/support/contact-us/
is Sony spying on users in this forum?
http://talk.sonymobile.com/thread/60197
UNRELATED topic, if you have some time please check this thread
that doesn't seem right, a Sony employee wouldn't suggest that you use flashtool, first PCC and SUS will do the same, update and reinstall the current software, flashtool allow you to do the same and to install previous firmware versions or firmwares from other countries. can you elaborate on your issues
I am having these problems-
1 android os consume 80 percent of battery when phone is left idle.
2.when i try to turn it off the phone restarts while turning off.
the service personnel told me tgat there is a difference when you update the software and we flash it with flashtool.
This seemed strange to me. Now what should i do???
repair your phone with SUS or PCC > do NOT install any app > test your phone if the problem persists if it does take it back to the store and get it replaced or contact Sony customer service
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
http://software.sonymobile.com/install_packs/Update_Service_Setup-2.12.12.41.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
I have tried software repiar but it was of no use, now what to do.
service personal is asking to flash my phone .
i want to ask that if there is a special software for service centre or they use update service or pc companion for updating the phone software???
Okk i will contact sony.
i want tobask that how the software is updated in service centre because i will not leave my phone there.
I will ask him to uodate phone in front of me
so can you give me idea that how they people update software??
they used to have SETool when they were Sony Ericsson, it should be something similar
Okk
Thanks a lot
