I own a SE Xperia ARC. Is there a way to make SD card as the default storage? All the downloaded content goes to internal storage, which needs to moved to SD with an app. I cannot download large apps this way as internal storage is limited.
Thanks
I have a lot of apps that I want to move to the SD card, but it is´nt possible, can anybody explaibn why it is like that? So despite having a 16gb SD card I am not able to keep all the apps I want becaus e when they are about to update there are not enough memory and the updates stop.
Not all apps could be moved to SD card.
It depends on the app and not the mobile
