I own a SE Xperia ARC. Is there a way to make SD card as the default storage? All the downloaded content goes to internal storage, which needs to moved to SD with an app. I cannot download large apps this way as internal storage is limited.
Thanks
i don't think any app can be of the size of 200mb
it must be the data files of that particular app
may i know which app it is if u can tell ??
and u can download it without any problem
data files would be downloaded and saved to sd card , so don't worry
Hai manohar,
There is no option to select like that. But, You can do it manually by Settings>Applications>manage applications. There u can move the applications not to proceed with third party applications.
Hi Balakrishnan,
Thanks for the reply. The problem here is different. The available internal storage of my phone, as of now, is about 40 MB. I want to download an application which is of 200 MB in size. Now, how can it be done? I can free up 20 MB max. from the internal memory.
Thanks
from where are you downloading this app..??
android market doesnt allows the developers to develop app more than 50 mb of size..
so 200 mb , its impossible...
if you are sayin that some data ( 200 mb ) needs to be downloaded after installing the said application , the data is downloaded on the sd card...
mark helpful and correct answers..
timings
lol :smileylaugh::smileylaugh:
i told gwhispererz about this issue of this forum
there is no auto refresh feature...
unfortunately we can't repair this website wit softwafre repair or pcc
i want to root this website
root the site :smileygrin: :smileygrin: +1 haha.... nice....
whats the software you will use..? superoneclick:smileywink:
my reply is going down and down
Ok guys..I think I got it wrong. It is not an app, it should be data. It is a game actually. Thanks for the info..
hmm
