What is this app in the xperia pro default home screen called... I started using Go launcher EX and I want it there, I also want to move it from the center screen to a second screen in SE default... TIA... any help would be appreciated
center of screen, it's text message notification... What's the app/widget/shortcut called??
its callled the timescape
just make sure you have enough space on the homescreen where you want to have the timscape widget..
just long press the widget and drag it to the screen where you want it..
or delete that widget by long press and dragging it to the bin which will appear after you have long pressed..
then in the scren where you want it.. long press on an empty space , select widget >timescape..
try the same method in go launcher..
ie long press on an empty screen , select widgets > timescape..
if its not there then unfortunately go launcher doesnt supports timescape..
Ahhh.. Alas, @slimshaddy... You're right... GO launcher does not support this it seems, it's not in the widget list... Many Thanks tho... so thats timescape... I had heard of it but never seen it so I didn't know this was it... lol... just got my xperia pro monday and I love it, although it's not as big as I expected, (I had expected a little bit bigger), I replaced an Nokia E7 with this phone, I Like both of them so much... I got the xperia because I read in several places it will be upgradable to Ice Cream Sandwich... I am torn between the two... The E7 is HUGE comparably and imho has the better OS for business... But the xperia pro has a better OS for fun stuff (games etc...). I'll probably use the E7 for travel and the xperia for around town... Oh and the E7 is better for watching movies and GPS stuff too... does anyone know a release date for ICS on xperia? Weird thing, I can't find very many cases for the xperia yet... Too new?? I'm looking for a bright green case?
hehe
well when i got my arc my condition was the same...
so its normal
like you love your old e7 i too love my n95
and yes its good that you take e7 while travelling...
its battery life's good i assume..
well pro has many features so comparitively less battery than te e7
thers no date for the ics
we'll get it soon
enjoy your phone
and if any questions , you know where to contact..
mark the thread as answered..
