Now, im rather new to android phones but i got the xperia play 4g from att. Its running the latest available release.
The issue is the cpu is at constant 100% usage. After looking around i found out that part of the kernel is taking around 80% of total cpu usage (running non stop). The file is located at system/bin/lidswitchd... Because its kernel you cant turn it off, so my question is does anyone know what its responsible for? maybe knowing what it does, illl be able to fix it.
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
don't forget to mark the Correct & Helpful Answers
Use one of these links to download the
Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
to get the latest update you need to debrand your phone, AT&T is really slow on releasing updates to their phones, so even if the latest update its available for SIM free phones or European networks AT&T won't release it
go to settings -> about phone and check
Android Version and Build Number
The latest update for the Play is
http://talk.sonyericsson.com/message/142139#142139
2.3.4
4.0.2.A.0.62
yes sorry wasnt aware of that, the build is 3.0.1.B.0.270... but wont changing the rom void my warranty? (its fairy new phone)
yes it does, unless you flashback the original ROM
but you can try to see if AT&T has released any new update
1) backup everything
then
2)
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
and also
or
How to install it
You need to
Contacts
open your phonebook
on your computer
Apps
SMS/MMS
or your SMS use
Call Logs
