I have a Live With Walkman and occasionally have to use an automated system. However, after being connected, I am unable to to do anything, i.e. the options will be press 1 to do this, press 2 to do this but the phone will not make any touch tone noises that the voice system expects when I use the keypad. What setting on the phone will allow touch tones to be used during a call after a call is connected?
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
don't forget to mark the Correct & Helpful Answers
Use one of these links to download the
Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
are you using a protective case that its covering the proximity sensor?
no, I am not using any case at all.
it says proximity sensor off?
how odd ok this is what I recommend that you do
1) backup everything
then
2) repair with
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
and also
or
How to install it
You need to
Contacts
open your phonebook
on your computer
Apps
SMS/MMS
or your SMS use
Call Logs
