Okay I have had my phone for about 2 weeks now, and I simply love the phone and all its capabilities, but there's one problem. Ever since I got the phone there has been the problem of me connecting to a PC. For example when I got my phone it was GB, I have had the issue of updating to ICS of which I used my MAC problem solved, but most of my music is on my PC and when I try to copy the music using Media Go, I have to wait almost a hole Hour to just let the phone create its thumbnails, I thought okay well its the first time its doing this... Until I plugged my phone out and plugged it in and did it again..... I decided not to go that route and try inserting them directly into the SD card's media / music folder and it started out at a good 15 minutes which was okay for the amount of music I was copyin over then turned into 6 hours .... and then not responding then crash... I'd like to know why is this occurring and if there is a fix PLEASE help me out here... I intend to get pictures from my phone without waiting 30 minutes on 3 pictures that = 8MB. Also I saw an update in the media go, and tried 3 times to install it all of which failed, I uninstalled PC companion reinstalled it and all of its features and it still gives these issues. please Sony, I love your phones and softwares and apps you put into them and from all my other apps I had from you guys this is the first I am ever getting these issues.
Please respond / email / leave a comment A.S.A.P thank you.
try SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
unrelated topic, if you have some time please check this thread
try SUS
Thank you I'll test it out now and if correct I'll tick, if not It was helpful and quick.
btw when you connect your Xperia S to your PC you can't access the internal memory? how old is your PC?
I can access the internal memory, however either the phone crashes on my PC or the PC companion crashes and disconnects the phone without the Drivers recognizing, my laptops a Dell Alienware m15x running Windows 8 Consumer Preview.
PCC it's not compatible with Win8
Thanks for the info.
anytime
