Hi everybody
3 days ago i updated my Xperia arc S from gingerbread to ICS with sony update service,
and now i am getting following command lines running on my screen...it shows diffrent command with opening of different applications.
pls help me to solve it.
Thanks
one more pic
go to settings > developer options > uncheck them all or just turn it off
Thank you very much:smileyhappy:
it has gone by simply turning off the CPU usage setting from there
Anytime
THANKS!!
i was getting this funny command line at the top of the screen on mine
and every time i touched the screen it left colored lines or dots all across.
ur solution resolved myy issue too!
