help needed... im not getting the shutter sound even i select any one of the 3 sounds.
thiw wil work 100%
download hide it pro...
https://market.android.com/details?id=com.smartanuj.hideitpro&feature=search_result
just download it...
open the software , avoid the pop up sayin how to use...
when you open the software , there must be an option of system volume...
increase it to 7 and now check the sound
it will work..
check whether ur phone is in silent mode or not
Setting > Sound > Silent mode (ticked or not )
Do all other sounds on the handset work okay?
thiw wil work 100%
just download it...
it will work..
wow it worked well ... thankyou
told you
also , question to moderators.. whey does this system volume decreases by itself..??
Hi,my name is shiva
please help me...when i am downloading apps from android market they are downloading in phone memory........please help me how to move them from phone memory to sd card
Download 'move apps to SD card' app from market.
you cannot ,
since your phone has 2.1 android version , you cannot move apps to sd card.. you just cant
this feature was added in android version 2.2 and up..
and your phone will not have any android upgradation so you cannot..
what you can do is install a custom rom of 2.3 android version..
