To check RAM go to settings>apps>Running apps. Bottom of the screen u can see free ram or used ram
To clear cache go to settings>storage>cached data. Click on cached data. It ll ask u to clear app cache.
This should be just fine.Settings-apps-running,from there you can also force close apps.
