IN GB 2.3 Full Charge == Bolt symbols in battery Get vanished........
What about ICS 4.0.4 === ??????
it should be the same, once the "bolt" it's gone it should be fully charged, or just press the power button and once the screen it's (w/o unlocking the screen) you should see the percentage on the top left side
btw you can NOT overcharge your phone
unrelated topic, if you have some time please check this thread
R u sure... Almost 4hr still i can see the bolt symbol......(mobile charging through PC) what should i do?????
that's normal, charging through a computer (not wall charger) will take quite a while, use the wall charger
Ok i will try that and Thank You...................
no problem
