hello to everyone...!
my arc s is not charging when is turned off
i turn off the device,and when i plug it in the charger,it shows me sony logo, -same time blue led- and then nothing.
i dont see the thunder any more as i supposed to ... 😕
could you please help me.? sorry for my bad english
okh dimitrissd here is the way
Since your mobile is rooted then download this
https://www.box.com/s/51ec05f25c6ff1196ca5
Move it to system/ Bin, copy and replace the older one
And yeah remember to change the permissions as
Hmm, this is a problem that even i am facing
Is your mobile rooted ?
Try connecting it to different wall socket , chrage with different PC usb CABLES
See if you find the same problem
yes it is rooted... 4.0.4.
i have no other usb cable...
but im gonna find one
The problem is because we both have a rooted mobile.
If you will reinstall your phone's software this problem will vanish. But as soon as you root your mobile, you will start facing this problem
No need to test it with different cables as i tested it with 4-5 cables and problem remained
so is there any way to fix this problem..?
in other words if my phone turned off because of 0% battery,i cant switch it on...?
Most likely yess... it's quite risky
And there is no way on a rooted mobile...
I will try to find a cause though
I had the same problem and after researching I found similar problem faced by an Xperia Mini user. He got his mobile repaired by replacing the "charger" file under system/bin/ and so did I replace the file "charger" from Sony Ericsson Xperia Mini and lol it worked!! Amazingly it helped coz I was going to repair through PCC. Still waiting for file named "charger" from Xperia Arc coz I don't want to use this Xperia Mini file and informed Nabeel who shall help me for sure
Thanks Nabeel! You doing Great Job!!
Also to let you know. Setting permissions for file named "charger" was not required !
thank you very much....! nice job!
