There is no notification when fully charged in Xperia SP when you have the phone in off mode.
However, you have an animation of the battery if you press a short click on the power button. The phone will not start, it will show you a battery and how full it is. And when the LED light turn green you have about 90-100% of the battery charged.
Last night I learned that displaying of this animation depends on the firmware flavor (same version, different region or sub-region).
I described similar problem in at least two topics on this part of the forum dedicated to Xperia SP and there was no solution to this problem of battery indicator not showing when the mobile phone is switched off (only the backlight of the touchescreen in switched on) and charging.
So, last night I put Central Europe 1 firmware instead of Central Europe 3 and the problem disapeared. I pushed the power button shortly 6 to 7 times in a row and every time this animation showed. When I returned to the original Central Europe 3 (1272-3354, latest 12.1.A.0.266) the problem reapeared.
In my opinion you have too many firmware flavors, and you don't test them extensively enough or you simply have bad beta testers.
