After many attempts backing up, I have finally done so......But when PC companion is 'preparing' to update..it doesn't. It says Installation Error...'unable to install or start phone software update componnets'. 'the update of software failed'. I have tried again, as suggested..but nothing..
HELP please...:)
forget about PC Companion, try Update Service
Hi Charl_23, if possible try with another PC/Laptop. Alternatively, you can update using SE Update Service, download from www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/xperiax10?cc=gb&lc=en. If still unsuccessful, try updating in Safe mode (reboot PC/Laptop, keep tapping F8 until a Safe mode Menu appears, select Safe mode with Networking and run SE Update Service). Good luck.
if it comes to worse then use FlashTool to flash the firmware
THANK YOU!!!
anytime
