A few month ago, my XPLAY can sent SMS to other phone..suddenly after a few weeks ago, i got this problem. (cannot sent SMS but can receive SMS).
After consult wif my service provider..they said i have to change the message service center..luckily i found this forum on how to open service center using *#*#4636#*#*..but when i try to refresh, iget refresh error.. then i try to put "+91MESSAGE SERVICE NUMBER",145 but then i got update error..so how to fix this problem?
btw..i'm using android 2.3.4...
thanks in advance..
Hi, sounds like a SIM Card problem .... suggest you test with another SIM Card.
If confirmed, get a replacement.
