My gmail app works perfectly
When I enter details of other email accounts into the email app - I cannot make the "next" button work (nor the manual button)
So I downloaded another email app "k-9 mail" and i had exactly the same problem!
I've tried it with the keyboard out and in - I can highlight the buttons - but i cannot make them register any reaction.
I have been trying to register other gmail accounts.
Any ideas anyone?
The phone is brand new from 02 in the UK
And through PC connection I updated the software - although I had the same problem before and after the update
running android 2.3.4
go to settings > accounts and sync > add another account..
yur phn can b synced wid oly 1 gmail(the 1 that yu register with yur android device) account na..?? try the simple "email" app its preinstalled.. i hav 2 gmail accounts in it..!
Thanks - that worked perfectly!
I guess that other email app is for non-gmail accounts
i hav a gmail account in dat email app...! its fr all the email clients mate...
Then, from my experience, I would guess you do not have your phone registered to a gmail account, or, you are not using the "gmail app".
i am using the gmail app...! its sync'd wid my gmail account which i gav to it wen i switched on the phone fr the 1st time... n yes , more accounts can b added to it...! noticed it jus now...
hmm
