I update my phone from setting/about phone/software update now my version is 2.3.4 and firmware is .69 now how can i root this firmware?
You can't root it until you flash an old kernel
either from .42 or .58
You first need to flash an old kernel, then root it and flash back the kernel from 69 update
From where i download the old n rootable kernel? N how cant i get flash tool n how can i flash?
Okh then first of all backup your current firmware
Just follow the green lines here, ( how to backup firmware )
After backing up your firmware
read this guide carefully -
In the given thread, read the topic how to root 4.0.4, and in that read how to flash just the kernels. ( step 6 )
Once you understand it get back to me
What you need to do is
Download 0.42 firmware, flashtool
Don't do anything, just be ready with the knowledge and stuff
I want to voice chat with you to explain my problems lets take a voice chat at skype dis is my id : vjhamad add me i need your help
Oops, sorry for that, i am not active on skype
I am really busy too, so i hope you understand
Please write here only
I will try my best to help you
Im on gb n firmware is 69 n my bl is locked n my mobile is not rooted
Then great buddy
Just follow the nstructions in my post above
First of all keep a backup of your contacts, documents and everything important
reinstall your phone software using sus
http://www.sonymobile.com/global-en/tools/update-service/
Then backup your firmware using flashtool
just follow the post above
Can i flash frimware 42 in my mobile with flashtool? My phone i unroot with locked boot loader
First of all to root, you don't need to unlock bootloader at all
and yess you could flash .42
Flash 42 and root your mobile and upgrade it using the update center app of mobile
