I'd like to learn how to turn off the shutter sound on my new phone. The sounds on the camera still makes me wince everytime I hear it, and it is just getting plain annoying. Any way to turn it off?
you can flash the global generic firmware and that will give you the option
this is how to do it
open the camera -> drag the menu -> left to right -> shutter sound -> off
When I open the shutter sound menu though, the only options I can see are Sound1, Sound2 and Sound3
there are some countries that are required by law to add a sound, that might be your case
Wow, thank you so much! It worked perfectly.
no problem
make sure you mark the correct and helpful answers
