Hello ı have this pixel problem does anyone have any idea of this problem ? what can ı do ? beause ı have last few months warrantly and if this is problem ı can send service ...
Check the video !
Video
You need to reupload or edit the link,it is not good.
Soryyy , ı updated now
I cannot see any problem.Could you explain for what I should look?
I mean sometimes ı see some green colour on my screen you can see in video at 0:10-0:15 or 0:23-0:27
Oh,it can be hardly noticed in the video.Do you have automatic brightness on whitemagic enabled?
Yes , its enable and automatic brigtness
You could try to disable it.See how it goes.
I couldnt found to disable it
ı can just change , automatic , daylight , cloudy ... and when ı change it there's no difference about green or black or some pixel colour
or how can ı change another settings ?
Go to settings-display,there should be brightness and do not set it on automatic(whitemagic platform).
