I've tried taking pics using the camera button, but all it does is focus and not actually take a pic, for that i have to tap the screen. Is that right or have I missed a setting somewhere as I thought the idea of the camera button was to take pics.
are you pressing the shutter button all the way down? it's a 2 stop button - 1st to focus, and depress harder to capture.
admittedly, the button is a bit stiff.
There is a setting similar to the problem you're describing. You can deactivate the touch capture feature. The camera button should however not be possible to deactivate.
Try to start the camera > press the menu button > Capturing method. Change to something it's not set to right now and see if that could make it work.
Also, read Ninehneh's comment above.
What do you think about this forum? Let us know by doing this short survey.
Cheers for the replies and cheers Ninehneh, it worked fine after a very hard press.
beautiful
Enjoy the phone!
