Dear Xperia care,
I have Sony Xperia Arc S when I call someone...and remove my phone from ear I can't see the screen that is I can't use my dial pad to end the call or some otherthing....is this sensor problem???...so pls help me techs out here.
Thanks
Nothing is blocking near or on the proximity sensor. I don't have any protective case, film or etc...
i tryed this application it is working fine no problem. But when i make a call or recive the not able to disconnect the call and not working display and any keys.
https://play.google.com/store/apps/details?id=com.sonymobile.androidapp.functiontester
Is there anything near or on the proximity sensor? it could be a protective case, film, etc
Any update about my question !!!!
Check this thread: http://talk.sonymobile.com/t5/Xperia-arc-Xperia-arc-S/Problem-with-proximity-sensor-Arc-S-in-bright-...
Worked with me
