Hi looking for call logs/clear timers etc. I have searched this forum, and the phone, and cant find the correct menu any help appreciated.
I know I can down load an app like Droid Stats, but surely this information must be on the phone!
you can only get the total calls (overall since you got the phone) but not by month, you need an app for that
open the Dialer -> press menu -> clear call logs
are you trying to delete the call log or the total time?
Hi I am trying to find call logs on phone, for information purposes, ie keep tabs on how many calls made in the month etc, then reset for the next month. Thanks
just open the Dialer and you will see them.
Sorry I must must be having a dim moment, yes I can see a list of all calls etc, but how do I get a summary of calls totals etc. Sorry if this is obvious but I can not see it. Thanks again.
Many thanks glad I was not having a dim moment then, it seems the more we progress tec wise, we start losing basic information tools.
lol phones are getting smarter but simple basic functions are lost
