Hi there!
I upgraded a few days ago from 2.1 to 2.3 and I am mostly happy with it. As I am still trying to customize the phone I am missing the "Call log" widget that I use to use a lot in the previous version. Either is there and I cant find it or they took it off. I dont know if anyone knows what I am talking about. It was a little box with the 3 last calls that I could just click and call without getting in to the phone/call log/clcik. I know I am getting greedy here but I really liked that widget and I cant find anything like it on the market. Can anyone help? May be I can download it from somewhere or may be something similar?
Thanks everyone in advance!
I'll keep looking the apk has to be somewhere
in the mean time
https://market.android.com/details?id=com.sonyericsson.zwooshi&feature=related_apps
https://market.android.com/details?id=com.spcampos.ucw&feature=search_result
they removed it, you can use Favorites and call log instead
Always immidiate response from you uliwooly!!
Thanks a lot for your answer I was kind of hoping you would say: "It is right there!! are you blind??!!" hahaha Have a nice day!
in the mean time
I'm glad I could help
Uliwooly I like that app toooooo. (It is normal Suze but stupid account won't let me log in!) Thanks for that oh master of the Android Market
Thanx suze, yeah sometimes this website acts up for some odd reason
hi Guys,
found the call log widget which was included in the 2.1 version of X10.
I've tried at least a dozen apps and none feels as comfortable as the stock one from the 2.1 version.
I used it a lot before and just can't live without it.
Here it is.
i didnt' realise it was called "Recent Calls" until i reviewed a youtube video demoing the widget.
i found the apk on http://forum.xda-developers.com/showthread.php?t=989897
hope you will enjoy your x10 a bit more.
Kevin
Hi Guys,
I used to use the widget a LOTTTTT before, and i've tried at least a dozen widgets and none is as comfy as the original stock widget from SE.
I just can't live without it after upgrading to 2.3
I didn't realise it was called Recent calls after seeing a youtube video demoing the widget.
so here it is: i found it on xda forum.
hope can help you enjoy your x10 a bit more.
Kevin
