This is the secondtime i have this problem. Somehow the call log goes blank. so i canot see any missed calls and other cal log information. it just is blank - without any sort of notificaiton.
First time it happen i had to factory reset the phone by updating the software - which meant i lost everything from my contacts to my apps - and it took me much time to get it back to my settings - however it worked ok then - for 2 months and now the blank call log is back.
Any idea of what i can do without resetting the phone?
thanks
open the phone app > menu > Show call log
is Sony spying on users in this forum?
http://talk.sonymobile.com/thread/60197
UNRELATED topic, if you have some time please check this thread
here are some suggestions to back up everything even call logs
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Thanks - problem completely sorted with this easy fix.
anytime
