My calendar will only display details of events up to one month ahead although it shows the blobs on the day without any limit. I cannot find a way to change this in the settings. Can anyone help please?
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Are you talking about the agenda view below the dates in the calendar? It's not possible to set it to show longer than a month ahead. You can press menu button and select agenda view to see more. Otherwise I suggest that you download a 3rd party calendar from Google Play with the feature you are looking for.
Thank you for your reply. I can see better how it works now, and I can live with it as it is.
