Hello there, i have been using my sp since february. on android 4.3, when i clean the cache memory with "clean master" or any other cache clean app, my phone is not able to do a simple task. it says on any app that is not responding and i force close it. it gets back to normal when i reset my phone from the back. it didnt do oi when it was on 4.1....and i cant remove the back cover and do all this procedure for like every day! please help.
So now it is better?Keep us updated.
right now it behaves just right. a coule of hours ago i re-enabled chrome, used it for a while, then ,i cleaned cache, data, unchecked notifications and disabled it. the cache of the chrome was around 1.60mb. when i cleaned it the same thing occured, but only for some seconds. then it came back to normal as it is now...
Good.Hope it stays like that.
yeah ill wait a couple of days and then ill clean the cache again and see what happens
I think you should pay a visit to a sony service,see what they say:
http://www.sonymobile.com/global-en/support/contact-us/
uninstall apps you do not use and also uninstall the antutu and cleanmaster and see the difference in performance i disabled all google apps like playgames,goole play music, google play books , video ,magazine ,chrome ,google one time init, google partner setuo, market feedbac agent,japanese keyboard layout ,news & weather . the phone works like a charm
This sounds great.Now the SP users are happy.
