Hello there, i have been using my sp since february. on android 4.3, when i clean the cache memory with "clean master" or any other cache clean app, my phone is not able to do a simple task. it says on any app that is not responding and i force close it. it gets back to normal when i reset my phone from the back. it didnt do oi when it was on 4.1....and i cant remove the back cover and do all this procedure for like every day! please help.
What have you installed lately?
It is hard to say if any of those can interfere,I am thinking about the Wifi app.
You should visit a sony service and see what they tell you.
@PanosGR89 wrote:
Disable Google Chrome.
Do this,it seems that these guys are right:
http://talk.sonymobile.com/t5/Xperia-SP/Solution-found/m-p/647611#U647611
