x
C903 won't start-up
SOLVED
Not applicable
C903 won't start-up
My C903 on startup gets only to the Sony Ericsson logo and the doesn't react after that - you have to remove the battery the shut it down.
The firts time it happened I took it in for repair, and they apparently 'reset' the phone, didn't actually repair anything (after waiting for two weeks). It worked fine for a month or so afterwards and now it's happened again. Is there anything I can do to reset it myself or must I take it in again?
The battery won't charge in the c903, but I recharged it from my wife's c902, so it's fully charged.
1 ACCEPTED SOLUTION
Accepted Solutions
KrazyD
Contributor
The phone is turned off when you are doing the update all you need to do is Hold the C button and insert the USB cable.
7 REPLIES 7
KrazyD
Contributor
Update the phone suing Sony Ericsson Update Service.
Not applicable
Can't do that - the phone won't start up! The phone is totally non-reactive to any buttons - you have to remove the battery to shut it down. It just stops at the Sony Ericsson logo.
I was hoping there is some secret way to do a hard reset from inside the phone.
KrazyD
Contributor
Not applicable
Thanks for the help - phone is now back in use (but must be some underlying cause I assume that it got into that condition for second time, or is it normal for Sony Ericsson phones?)
KrazyD
Contributor
No its not a common problem I'm not sure why that happened to you.
Not applicable
i also use C902, and it is experiencing the same problem as the one with the C903, but i have done that update and it still can't start. it still have the sony ericsson logo on it. please help me.
Not applicable
My C903 had also started reporting that the 1Gb memory card was not available, so I removed the memory card and since then there has been no repitition of the no-startup problem. If you have an additional memory card, try removing it.
